BeoRemote One BT functions, tips, tricks?
LIST -> Settings -> Buttons -> <Button> -> <Function (i.e. Lights)>
One thing that doesn't work for me is addressing individual lamps.
With the Beo4 you'd press LIST until LAMP appears, and then press 1 to address the first lamp.
Here you can access the LAMP function from the list but it sends the LIGHT code rather than the LAMP code!!
They told me it was a known bug in the firmware. I got it flashed with a new one and it still doesn't work :-(
On the BT version (the one I have ) it does not work that way...
I still haven't found am easy way to control light.
It seems that alex_112   has - hmmm?
For those of you with a BeoRemote One BT and an android phone, you can pair them and use the remote to navigate around the menus on your phone - pretty pointless, but fun to try 🙂
Personally I could live without that.
As long as I would be able to adress my light scenarios (I use mostly 4-5 as a combination of 4 individual lamps) and dimm/increase these with ease, I'd be fine.
P.S. But if there is a bug there, they ought to get it fixed.
Any idea of usage with third party products? I can see blinds etc under "Control", is there a compatibility list?
These commands are passed to a BLGW if you have one, then the BLGW will command the blinds or any device. The remote does not control things directly .
So this "455 kHz for Bang & Olufsen products and 20-80 kHz for third party non-A/V product control" is not actually the remote which sends but rather the BLGW IR-transceiver? Or is it something else that's the 20-80 kHz?
If someone can show me how to configure the light function into a MyButton I would be very grateful 🙂
You have to switch now from bluetooth to IR, lot's of steps to control the light. After that, you have to go back again all the steps to switch to bluetooth (TV function) again. Not easy, and very clumpsy..
