Actually it isn’t that hard to understand.
Any (ir-based) BV, that can be controlled by a Beo4/navi, can be controlled by a BeoRemote One (ir).
Some BV’s had the option to choose between navigating with or without the navi stick (instead of the arrows).
By some of these it was a matter of sw version, whether they could or not - and hw version in some cases.
All newer (again ir-based) BV’s are made for controlling via navi per default.........and therefore also works with the BROne (which was the delievered remote for these tv’s).
If you have a BV with the choise of controlling with or without - and it is set to navy, but you only have an oldschool Beo4, there is a solution.
You can use the digits counting the menus from above....means: instead of navigating with the arrows you enter the 1, 2, 3 etc for the ‘number’ of the menu, you want to access.
This way it is possible to navigate to the menu where you can change to ‘old school Beo4’.
