I managed to use Beoremote One with Beovision 9 and Apple TV by using Beo4Video mode. But the Navigation keys (arrows) don't seem to work neither on Apple TV nor on BeoVision 9 menues. So right now Beoremote seems to be less funcional as Beo4. Any Solutions?
Beoremote One, Beovision 9 and Apple TV: Navigation keys don't work
Hi and welcome to Beoworld!
Is the remote in Mode 2? From the manual:
Beo4 modes (MODE?)
MODE 1 When a Beo4 remote control is in MODE 1, the navigation button is used for menu operation, and menu and source operation are separated.
MODE 1 should be used if:
– all your televisions in your video setup contain the ‘REMOTE CONTROL’ or ’BEO4 SETTING’ menu and are set to ‘NAVIGATION BUTTON’.
MODE 2 When a Beo4 remote control is in MODE 2, the navigation button does not work and menu and source operation are not separated. MODE 2
should be used if:
– one of your televisions in your video setup does not contain the ‘REMOTE CONTROL’ or ’BEO4 SETTING’ menu …
– you also use a Beo4 remote control without navigation button in your video setup.
Set the ‘REMOTE CONTROL’ or ’BEO4 SETTING’ menu to ‘NO NAVIGATION BUTTON’, where possible.
Reset your Beo4 (RESET?)
For resetting your Beo4 to default, all settings will be deleted. Select RESET? from the LIST menu.
But I don't think that the NAVI button will work with BV9 whatever.
Sounds very helpful, thank you.
On my Beo4 the navigation buttons work quite well with BV9, Apple TV and the STB from Technisat.
I just looked into the Beoremote one manual, can't find how to deactivate "mode 2". Do you know, how to do that?
Many Thanks!
Press Standby and LIST together, whereupon ADD appears.
Press LIST until MODE appears.
Press centre button
Use arrows to select required MODE
Press centre button again.
EDIT: And then a long press on BACK will exit setup.
On second thoughts, I am confusing myself as I have been talking about Beo4 NAVI all along - apologies!
... but if you look at P16 of the Beoremote One guide, you want to set it up as a 'Beo4 Video' product.
That's what I did, Beoremote one is in Beo4Video configuration. Everything works except the navigation buttons. Can't figure out, why.
I think it's because the BV9 won't respond to the navi commands. Newer TVs have the option to set up the remote (receiver) function to use the NAVI version of Beo4 - the one with the little moveable button in place of the GO button..
I`d try to set the BV9 (BS3) to "NO NAVIGATION BUTTON".
Stefan
That option isn't available at the BS3mk1 inside the BV9 mk1-3.
I've just found a BS3mk3 with 2x hdmi out. Haven't checked if that option is available.
