Beoremote one and BV Eclipse
HiA question for those who use a BR1 with a BV eclipse. As i face some disfunctionality of the remote i wonder if this is due to the remote. Or maybe caused by sw of the eclipse (or remote).Example. I cannot use Mybutton function for use with a BV eclipse? Also i am not able the replace list functions. Any suggestions?Maybe my remote version is not compatible with eclipse. See picture Login to view image
Same here, was told they haven’t integrated it yet and will come some day. In december i was told late january/early feb, but who knows with b&o nowadays
Can anyone with an Eclipse confirm that the four My Button shortcuts now work?
Yes they do, was implemented a couple months back. I got a my buttons keypad like yours to replace my Netflix one.
Wonderful. Thank you.
Does it work now?
Mine doesn't..... Software upgrade needed?
Oh yes, the my buttons have worked for a long time now with the Eclipse. You should ask your dealer to check your remote to see what is wrong.
