BeoRemote One - button backlight
Hi everyone,
Is there an option to have the buttons on the BeoRemote One backlit?
The list screen is ok, but I cannot see which button is which in low light.
Very much hoping that I have just got this function turned off somehow…
Tom
That is something, that quite a few beoworlders have asked for.
It is not possible with the current version.
Maybe there will be a version 2 (or another beoremote) with this feature at some point…..or maybe not!
Hi MM, thank you for replying!
Glad (I think) that it wasn’t just me missing something obvious such as a ‘remote-light-on’ button..
It’s such a shame as the remote looks and feels great, but becomes useless in the dark!
Thanks again for confirming.
Tom
Tom wrote:
........ but becomes useless in the dark!
I don´t think so.
The BR1 BT version has 2 strikingly increased lines " to feel " the most for daily used keys in the dark.
When you has a good memory than it is no problem. The most keys are under "List" so you only learn this location 😕
Sure would be nice to have a button backlight but when in this way the design and the feeling is gone ... noooooo way.
Never change a running system 😁
