I bought an s3 with intention to use it with usb connection. But after fiddling around I prefer the audio in.
Will the speaker benefit with a good quality DAC.? And Will it benefit with a DAC with better sampling? If I play a 192khz / 24 bit stream over the audio in port will it downsample the steam to speaker's native sampling or play at the passed rate. I think the speaker's own usb port supports 48khz/16 bit.
Any DAC suggestions that would pair well with the s3?
