BeoPlay S3 and Chromecast Audio
Perfect, thanks. I'm guessing you are playing each speaker in single point stereo?
It would be great if Google issue a software update you that you can select if a speaker plays left, right or mono. In the mean time I'm going to try the cable hack to see if I can get left and right.
Nice - and how does volume control work in daily use?
Do all 4 respond the same, when you use the control via the sending app/device?
Do the S3’s remember their own volume settings, after being in standby - or are they maybe always on?
