Beoplay M5 und Beovision 10-46 verbinden
Hallo Forum,
Ist es möglich diesen Lautsprecher mit diesem Fernseher zu verbinden?
vielen Dank
Use the BeoLink NL/ML Converter for this:
Thanks MM,
as I have already a Beolink Converter 1601 in use to connect my Beovision 10 and my Beosystem 7000 my Masterlink Port is blocked. Is there any possibility to use them all 3 together?
You can easily split a MasterLink cable - just use a ML junctionbox to have more endpoints.
