Hi All,
i have been working on a friend's BM8000...so far so good, but it displays some unexplained erratic behaviour:
1. After been unplugged from the mains and reconnected it takes a couple of unplug-plug in, unplug-plug in
before it finally comes out of stand-by ? Once that has been overcome it performs as it should?!
2. Adjusting the volume up to say 2.8 or higher it all of a sudden comes on full blast with the clipping light on
3. Using the speaker 1 input it does not go entirely quiet at 0.0 volume plus the clipping issue being present.
4.using the speaker 2 input everything seemed to be fine but after an hour or so it goes into clipping again with full blast volume......
would it be fair to assume a processor board issue ? Could it be crystal oscillator related ?
The unit has been fully recapped, new trimmers on the output amps, no-load current adjusted, dc offset adjusted, contacts cleaned, solder joints at connectors partially reflown where necessary, both start-up relays replaced.
I would really like to help out the friend and be most grateful for some pointers if possible.
thanks
ALF
