More work hours spent 🙄.....
1st swapped the uP board only from the donor unit (uP test passed) - vol issue unchanged.
2nd swapped interconnecting cables - vol issue unchanged.
3rd swapped unrestored preamp board from donor unit - vol issue unchanged.
as said before, unless both tone/filter boards have faulty vol attenuator ICs and both preamp boards are faulty
I almost dare to say the problem could/should be hiding somewhere else in the unit ?!!
but where 😳🤬😳 !!
yes, we discussed the unlikely fact of having two faulty sets of vol attenuator chips I still want to dismiss that option.
both uP boards seem to do their job...is it unreasonable to conclude a problem in the output boards ? But,
I was always under the impression the unit would not switch on if there are problems on the output stages (fault switch !)
Seems we (I) need more brain-power here ...... just got that feeling I am almost there.......
if you guys have any further information call “crime stoppers”
ALF
