first a little bit about my setup
Beosound/beomaster5,beolab 18,Rotel RCD-12 cd player,Rega turntable,playmaker
and a behringer uca 202
i have tried a UCA 222 and even a UFO 202 still same problem the weird thing is when playing from internal harddrive from beomaster 5  there is absolutely no problem
is there anyone in here that have tried another usb card ?
when i try to play a CD,LP or stream through the playmaker the sound is extremely bad
i wrote to beocare they had never heard about the problem
does anyone in here have a good idea what i can try to do ?
i also have cloned the HD to a 2TH HD so i tried to use the original HD still same problem. i have tried to do a recovery without any changes
i went into to the system menu and tried to reinstall the usb drivers still same problem
i have an old beosund 3200 that i use right now and everything sounds perfect with that
Michael
