Howard_Johnstone wrote:
Thank you very much for your answer.
It helps a lot to be constructive
rather than just negative, as this do not bring the discussion
further.
Transistors:
At the time of design and production
these units where available and at low cost.
They had insufficient encapsulation
that cause substrate corrosion and gold bond
wires that will show up as the ”purple
plague”. All this degrades NOS transistors
and limits their use to low power only.
At full load they will eventually blow.
This does not apply to many of the
small signal transistors used, they where/are o.k
as long as they are not put under load,
high temperature or damp/wet environment.
Today when old motorola (semicond.) is
run by ON semiconductor, excellent products
can be provided even in the original
format, TO66 and TO3 without any problem at all.
However, they are aftermarket products
and will cost. Therefore old classics such as
2N3055 can be provided as MJE2N3055T
(TO220) at very low cost as replacement.
It was wrong to select the use of
2N3054 in the first place, and they knew it.
I have used D44H11G (TO220) modern and
of excellent performance at low cost
and will give you a much better SOA,
equals peace of mind.
Today Mouser, Digikey and RS components
provide safe and secure certified sourcing.
They will never ever knowingly provide
counterfeit as they could be sued.
Buying counterfeit at Ebay is
stupidity....
Rectifiers:
The inrush current values goes down,
especially the small tuner bridge (BM3000 to 4000)
no matter what capacitors are in use or
will be selected. If they fail the transformer will
be in perill, just as you have
experienced. If the transformer is without defect (E-core)
it will hold to a load corresponding to
about 70W RMS without overheating. (5 mins).
Only in the BM4000 do you come close to
this, tested with low-impedance 18mfd/80V.
Original rectifiers, wrong fuse, defect
transformer (humming) and the transformer will
be shorted/overheated no matter what
load (short) or use it is subjected to.
Original rectifier (PSU) is an accident
waiting to happen, why take the risk?
Capacitors:
Today, almost all electrolytic
capacitors will be or be close to low ESR (impedance)
capacitors as the electrolyte keeps
improving and the market demands lower impedance
as a matter of fact. Unless using NOS it is/will be unavoidable.
I have tested this
on BM4000 at full load and if the amp is in order
there is no problem with the
transformer or any problems with self-oscillations, which
is a sign of stability problems in the
stage itself; again, old transistors, bad SOA.
Using 15 and 12mfd respectivly in
BM3000, BC3500 and BM4000 I have not
experienced any thump or noise
whatsoever. (18mfd in BM1400) Unless there is
a leakage (which is heavy with the old
capacitors) there is no DC component that cause
thumps, noise or damage to the
crossover/vcoil in the speaker. (D. Self et al audio design)
There where bad compromises when these
where new; bad rectifiers, small capacitors.
But 2N3055 and MJ3001 was a correct choice at the time, but the drive stage was not
and had to be revised. The power stage
(PSU) of the BM3000 series was underused,
but the BM4000 was a simple improvement
(darlingtons) which gave much more
output from the same size PSU.
All this refers to AC-coupled
amplifiers, which are easy to handle and get in order.
Therefore I would challenge these to a
much better performance than when new,
when a recap and other rework/repairs
have to be done in any case to the chassis.
DC-coupled amplifiers are an entirely different matter, bode plots show a SOA that
limits everything to a very tight
order, usually a large rebuild is then required if something
has to be changed (BM4400). That design
was much more up to date and appropriate.
Today, of course, AC-coupled output
stages are a thing of the past.
Regarding transistors;
Gold-plated pins do not oxidize.
Same goes for tinned pins.
It's the bare (untinned) pins that oxidize (like some BC182/BC183 etc.).
No 2N3055 transistors (be that NOS or used originals from B&O) have untreated pins and none suffer from any plague (most are in fact gold-plated).
B&O used RCA and Motorola primarily. They are all excellent components that will stand the test of time.
The most often seen transistors with bare (untreated) leads are the small signal ones (BC182/BC183 and the occasional MPS5418 etc.).
Never the power transistors.
And no power transistors are pushed to their limits in any B&O.
F.e. the 2N3055 is used in Beolab 5000 (rated at 60 Watts per channel) and Beomaster 3000 (rated at 30-40 Watts per channel) - each of them using two 2N3055 transsitors per channel.
The producer rates one 2N3055 at 115 Watts alone...
Regarding counterfeit components;
"Today Mouser, Digikey and RS components
provide safe and secure certified sourcing."
- I have returned counterfeit parts to all three. All handled the returns professionally, understanding and cooperative.
"Buying counterfeit at Ebay is
stupidity...."
- I often advice against buying from Asia, but stupidity? Well.. I think I would rather put it down to lack of knowledge and expericence.
I'm sure no well-reknowned suppliers "knowingly" supply counterfeit components.
But the market is a maze and a jungle.
As mentioned above I have received counterfeit components from even VERY well-established and trusted suppliers, - and I'm sure they didn't know, until I told them.
"It was wrong to select the use of 2N3054 in the first place"
Where did you find 2N3054?
As far as I know B&O never used 2N3054.
I am not familiar with it anyways.
B&O used 2N5034, which proved to be an incredibly sturdy and relible output stage transistor (think Beomaster 1001/1200 and the earliest 1400).
I have replaced only very few of them, and it was typically when owners had accidentally shorted an output stage
They are VERY sturdy components.
Rectifiers:
"The inrush current values goes down, especially the small tuner bridge (BM3000 to 4000) no matter what capacitors are in use or will be selected. "
- What?
With a low-ESR (low series resistance) capactitor the current goes up. That's Ohms law.
"the small tuner bridge (BM3000 to 4000)... - ... it will hold to a load corresponding to about 70W RMS without overheating"
- Absolutely not.
It will not carry 20 watts, - and it was never designed to.
The original part is a very small (Siemens) rectifier. Its only job is to power the tuner and preamplifier section, - not a huge task - but still they fail because they break down physically due to their construction.
A better replacement is, as mentioned previously, the very common W06. Not a particular powerful component at all, but by far adequate for the task.
Rush-in current:
You talk about Beomaster 4000.
I am talking about Beogram 4000 (the first tangential record player from B&O).
I have lost count of the owners fitting low-ESR filter capacitors only to ask for a replacement transformer thereafter.
Been there myself, not proud to admit, but my excuse was that I wasn't as experienced then as I am now thirty-something years and hundred-something decks later.
(BM3000/BM4000) "Original rectifier (PSU) is an accident waiting to happen"
- I have replaced only three or four in 40 years. That's considerably less than the number of rectifiers I've replaced in more modern units.
Capacitors:
"Today, almost all electrolytic capacitors will be or be close to low ESR (impedance)"
- Eh.. no.
You can still buy excellent "conventional" capacitors. I have done so as late as last week.
"if the amp is in order there is no problem with the transformer or any problems with self-oscillations"
I can tell you, that is NOT the case.
I have had many amplifiers on the bench, that had run astray for "no apparent reason". They just went "poof", even
when running at what seemed to be low output or silence, with clear signs of overheating.
Beomaster 5000 (that didn't have the extra capacitors fitted to the output stage, that was later fitted to Beomaster 5500 etc.) is a definite example. Typical tell-tales are the 4,7 Ohms resistors R131 / R231 at the outputs.
They will burn if a high-power high-frequency signal is present.
And they can REALLY burn - they should ideally have been flame-proof types, but curiously they aren't.
The original transistors will never be the cause of self-oscillation.
If anything they will lose Hfe with age, and that's rarely a problem.
The problem comes if you fit high-hfe transistors in a DC-coupled output stage. That's asking for trouble.
Particularly if you also fitted low-ESR caps in the output circuit.
Everything gets "too eager".
Not good.
Thump-sound;
Look at the schematics and tell me, how the output series capacitor is charged at power on.
Through the connected speaker - right? There's no other way.
A larger capacitor will take a higher current and/or longer time to charge. = Louder thump sound.
"but the BM4000 was a simple improvement (darlingtons) which gave much more output from the same size PSU"
The same SIZE, yes. - But not the same PSU.
BM3000 and BM4000 use different transformers (BM3000: part# 8013080, BM4000:part# 8013115).
Of course, you can construct better circuits today.
Actually, that was possible already way before the construction of BM3000 and BM4000.
None of the BM3000 or BM4000 were the best construction possible. - And none of them ever claimed to be.
They were excellent, stabile and reliable daily-use livingroom receivers delivering excellent performance and superb looks for decades without much trouble at what was still a reasonable price.
They were very popular and surprisingly many are still in use today - unserviced.
You want BM3000 and BM4000 to be something they aren't and will never be - unless completely reworked, which would be a shame in my opinion.
Is producing units that aren't top-notch, all-systems go, bells and whistles galore, what you call "bad compromises"?
Not all buyers need top range - or want to pay for top range.
I'm not sure, what it is, you are trying to tell us.
That we are all wrong, doing everything the wrong way?
That B&O was all wrong?
What?
