Beomaster 901 TR1 in FM : MPF120
Hi all,
initialy I have problem similar of this topic : /forum/general-discussion-and-questions/beomaster-901-weak-fm
I change caps and some resistance and it's works BUT FM is not normal...
As i have 2 Beomaster i can identify the guilty :)
In FM section, the Dual Gate MOFSET TR1 ( MPF120) doesn't work, i switch with the other beomaster 901 (who works fine)
So i need to change it but it seem not very common... in fact in my second beomaster it a RCA 605 40822 but same thing... i can't really find it.
Someone know with which parts i can change it ?
Thanks a lot :)
(soorry for my english, i'm french ! )
RCA 40822 can be found on Ebay
https://www.ebay.de/itm/203085023724
(I don't know and have never dealt with this seller).
MPF120 can also be found:
https://www.ebay.de/itm/174312361573
Thanks ,
For 40822  15€ for 2
For MPF120 22€ for 1
i think it's too expensive.
there is no equivalent transistor more common i can use ?
You can buy the correct parts.
That's a good price, I think.
But of course, it's for you to decide.
Actually, I was surprised to find them on Ebay, so if you don't buy them, I could feel tempted, just to have them in the drawer.
Modern mosfets usually have a much higher gain, requiring a bit of circuit redesign, and it's rare to see dual-gates used today anyways.
But go ahead if you prefer, - take your time and look around for something with similar specs to the originals.
Do let us know if you find something.
Thanks a lot for your response and good advice, as always ! :)
I found this : https://picclick.fr/3-x-RCA-3N204-273077271460.html
description : "RCA 3N204 Dual Gate MOSFET 40673 40822 3N201 remplacement Transistor" i don't know if it will help me or not.
Here on Ebay:
https://www.ebay.de/itm/402290096014
Not exactly cheaper...
I never tried that type, so I cannot say if it'll work. But you could try.
