New to B&O world and was really excited when I recently bought a Beomaster 901 with Beovox 1702 speakers and a Beogram 1202 all very dirty and in need of a super clean. That would all be be quite straight forward but sadly the RIGHT speaker input on the Beomaster is faulty. I could really do with some suggestions as to the problem.
I have tried both speakers in the socket and I have also tried the tuner in case it was a damaged pin on the Phono plug which was at fault but not the case! The tuner works fine but only through the left speaker. The 2 wires for the right speaker socket seem to be well soldered and there is no crackle when moved. These wires, one green and one blue and white stripe - the green goes to the headphone socket and the blue disapears off under the circuit board, there's a lot of dust !!!
There is sound from the right speaker socket but is is very faint and broken. There doesn't seem to be an obvious signs of a loose connection so I am completely stuck... any thoughts or help would be much appreciated.
I have a very nice cuircuit diagram that I found under the top of the Beomaster but hey... I'm no engineer!
James
