Hi all!
So I recently acquired a Beomaster 900K type 2232. I would like to carry out some refurbishment work on the unit - electronically as well as cosmetically. It's currently working but does have issues. So a few questions if I may 🙂
1) The bulbs have all failed. They are listed in the schematics as 6.3v / 0.3a for the dial and 19v / 0.1a for the stereo indicator. Would 6.5v / 0.3a bulbs be acceptable for the dial and 24v / 0.125a for the stereo indicator?
2) The unit sounds OK but bass distorts at reasonable volume level - any pointers as to what may be causing this?
3) The FM scale reading is way off from broadcast stations. How would I go about re-aligning it?
4) What are the usual recommendations with regards components to replace and any other things I should check / look out for?
Many Thanks!
