HarryPierce wrote:
I understand from your discussion that all IR LEDs are compatible with any IR receivers in terms of emitted light wavelength, i.e. it would not matter if I used an IR LED with 850nm output or one with 940nm?
Yes, it will work - the sensitivity might be reduced a bit if the peaks are far apart, but as long as it is a regular IR LED, it will be fine. The carrier frequency doesn't need to be exactly spot on either, within +/-5% should be fine.
I have never paid much attention to the LEDs, I've used LD 271 as they were readily available... and what do you know, the Terminal seems to have those as well ๐
Remember that if you simply drive the LED(s) directly from the Arduino I/O pins, the range will be rather short. With a series resistor that keeps the max current at a safe 10 mA or so, you can expect perhaps one meter. The real remotes use all kinds of circuit tricks to send shorter but larger pulses through the LED to increase the range. The two-way transmitters in the stackable Beomasters for example use four LEDs driven from a 40V supply!
Test the circuit with a regular red LED first. Once you get it flashing, you can replace it with an IR LED and keep it close to the receiver. Once the control actually works, you can start tweaking to increase the range if needed.
