Beomaster 8000 tuner problem
Hello
I cam across a BM8000 with some problems.
Half of the led were dead but got them all working again (bad connection between board)
Remaining problem is this: TP1, TP2, PH works perfect. But the tuner is another story
I get noice ((like between two channel noice). Added to this noice: a "pulsing" noice that
seems to increase in frequency (pulsing) as I increase the fm-frequency (tuning)
The "vu-meter" is also pulsing.
Anybody got an idea?
Best regards Lofke
Hi there Lofke,
dis you get that beomaster 8000 working again? I m having the same problems with mine.
 Greetings Steven
I don't know if it can be related but today, when I opened my unit, I forgot to put back the tuner plug from the microcomputer, which is well hidden under those ribbon cables. Could it be a bad connection there? The plug is shown here, under the green circle :
Guillaume
Hi there, i checked that but there ‘s no signal.
Thanks for the reply!
steven
Can you display frequency ?
Hi Jaques,
Yes the freq display is normal and bright as it should be.
When turning the freq dial it goes up and down as normal.
All i hear is static like it can’t find a radio freq.
then all of the sudden i hear a very short period ( say 3 seconds) radio ( freq 89,5)
 but that goed away and leaves me with static again. Tuning it further the same radio freq comes up somewhere else ( around freq 95,5 or so)
Thats also 3 seconds and goes away.
i can do the same over and over again.
Okay then.
I'd double-check every connector (remember there's one between the two tuner boards) and only then would consider something else.
And "something else" could mean opening the processor and memory can...
I was afraid you were going to say that, but thats what i am going to do.
checked and doubled checked every conector and connection between boards.
stil no signal. so i will have to open up that memory box and resolder and check everything inside.
Thank you Jaques!
Hi Jaques,
I fixed the tuner problem.
I replaced the prescaler inside the processor board.
Tfk
U264b
All is working Again and great reception.
Greetings from the netherlands
Steven
