Excellent! Get me two of those please!
Rudy you are the Master of the Masters.
Yes. Of course! I can get a few more printed. I'll be happy to supply them. Just send me an email to beolover@gmail.com.
Rudy
A brief update: I redesigned my laser cut speaker switch adapters for a more satisfying fit without the need for glue. I also made them from thinner plexiglass to avoid the Dremel thinning-step...Details at my blog:
Here is a little update on my recent progress in the Beomaster 8000 department: I recently refined my method to restore the damping of the volume wheel. I am now using a 3D printed 'paddle wheel' together with damping grease to affect the damping. More details on my link.
Here is a picture of the stereolithography part:
Thought I would share this one on my 8000 thread: I created another 3D printed part for the 8000. Three weeks ago I had the strange occurrence that the spring of the control panel lid broke out spontaneously, sending a piece of plastic shrapnel past my head, while I was sitting next to the unit...never knew that Beoloving could be dangerous!!...;-)
Here is the link: http://beolover.blogspot.com/2015/05/beomaster-8000-broken-out-control-panel-lid-spring.html
And a couple pictures:
Very nice one, Rudy π
Soon we'll have a completely 3D printed Beomaster 8000 π
As an aside, I also admire your work on the Beogram 4000.
A good time to thank you ruby, I followed your blog step by step for weeks on end to fix up my bm8000 with great success , has been performing brilliantly for a couple months now thanks
and until reading this without the use of safety googlesπ
thankyou it's been invaluable
Jason
and a special thankyou to Martin for doing the led displays which is the only part I chickened out of doing
This is great! I am glad you got your 8000 up to spec! Beolove is in the air...π
Here is another interesting part I recently developed for the 8000: SMD LED boards as replacements for the indicator light bulbs:
Picture:
Very nice indeed, and professional looking ,
I had followed your first fix with red LEDs and resistor and currenty doing the same on the beocord 9000 , I'd been toying with using white then making some replacement plastic filter covers in either white or green to match the green on the beocord display that I thought may look good
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
