Well, after having my M100's phaselinks repaired my Beomaster 8000 refuses to startup properly. It does display the decimal dot, and does click it's relays when pressing "0", and responds properly to the volume control and other commands, but within a minute it freezes with just "0" in the display.
Odd: when I unplug the machine and try again immediately no button responds, but when I leave it off for a few minutes I can repeat the cycle.
Pressing "0" and the Monitor button simultaneously to start the test program correctly displays "TP" (Test Passed), if I press those buttons quickly enough. If I'm too late, after half a minute no button responds.
I unplugged all cables to other circuits so I only have the computer and it's display, and I still get this behaviour, so my assumption is the problem is located in the computer board.
Found link where sort of similar behaviour is described. Apparently one remedy is to replace the 2MHz crystals, and re-solder VIA's. My board seems to be an older one than most described (mine is 1980, judging the chips date stamps), there are only very few of those on my board. But, the more extra components soldered on. Gosh, such an ugly board:
Re-soldering the VIA's with a bit of wire did not help, now awaiting delivery of the crystals, as my local electronics supplier did not have them in stock (grmbll).
If all else fails what I will do is simply replace the computer board with an Arduino. I see the protocols for the display are described well, and also controlling the amplifier can't be difficult. The volume and radio frequency are just rotary encoders, and those are not difficult to read using Arduino.
Arduino also has 1024 bytes of EEROM storage, so I can store frequencies there too.
Stay tuned...
rick
