All right, I just picked up the unit from the audio shop, it indeed was the 5V supply. So, it is up and running now!
Just one strange thing, I can't measure any voltage across the power resistors at TP200/201. On the left amp I did measure voltage and adjusted R226 to 18mV. I just ran the amp at full volume and it works fine on both channels... so seems a bit weird.
Also, how should I go about doing the offset adjustment? I measured the voltage at the speaker outputs and it just jumps around, 1 or 2 mV up or down from 0. Is that ok?
Glad to hear it :-) Now have you replaced the trimmers? If not then do so next before you end up back to square one!
Not being able to set the bias current obviously suggests there is another fault somewhere and you need to get to the bottom of that before putting the amp to use or even working in other sections.
