Yes, it is not variable. So by doing this it will at least give a lot of volume, probably only for a short while.....
Beomaster 8000 connection to Pentas II
Take out the Lab 150 amps & displays & sell them on ebay. This will give you a pair of passive penta's making best use of your set up & you will probably also get more money for these than you paid for the entire speakers in the first place.
Chris.
Hey everybody,
Right now I am using the Pentas alone (BM8000 is under re cap) with my computer and the RCA line in, but I have an issue. I do not why the volume decreases surprisingly and I can not recover the original volume. Sometime when I turn on the Pentas they work find, but later the volume decreases. Please help. What I am doing wrong.
Thanks,
Juan
Are the amps going into standby due to too low signal level? (red LED?) If they are try increasing input level in the flap and check your laptop volume is adequate...?
