Hi to all...
Back with my distortion problem which has been unresolved since the past 4 month... In the last month I reopened the machine two times and found out some strange behaviours. I'd like to have an opinion on that:
- A few weeks ago, after a first check-up, the clipping light shows out for the first time. So the distortion is a clipping problem...
-Probably a crossover distortion problem: the idle current adjustment is set to about 4mV π.
However, turning the pot clockwise does not change a lot: I could go all the way up and it would barely go to 6 mV. (I'm avoiding doing that, I know how it is supposed to respond when operating properly, and I know the relative position of the pot when it's set to 18mV. I let it this way to avoid any fireworks. (pointing at about 35-40 minutes...)
Assuming that the pot is brand new, that all the caps have been changed and that the emmitter resistors still shows a good value, what can be the cause of this too low voltage between them when idled?
-The offset is set dead down to 0V
-The distortion occurs sooner or later depending on the level of the input
-The distortion does not occur using headphones and turning off the speakers switch.
-I've reflowed the solder joints, especially under TR207 and TR2011 which showed some cracks...
Thanks to all for your input...
Guillaume
