Hi to all,
My Beomaster 8000, which has been unfaulty and perfect since 3 months now, displayed yesterday some strange behaviour. The right channel (which has never displayed any faults at all) has now a lot of distortion in the low frequencies. This is most apparent as I turn the volume up.
-Caps and trimmers are all new
-It is not caused by the speaker switch
-When using the headphones, I don't hear that problem
With my past experiences, and having learned from some of you, i'm suspecting a crack solder joint somewhere on the output board. (It's getting old and hot in there because of the power supply). Or could it be the yellow output wire to the speaker that can be loose since the sound from the headphones appears to be fine?
I'm confident I'll rule this problem out easily, even if i'm nervous to open that thing again, but does anybody has experienced the same thing before and what was your solution? For now, I'll check in the next few days if it's intermittent or not...
Thanks!
Guillaume
