Hi everyone!
Yesterday I had a crazy recapping session through all my Beomaster 8000 (except the capacitor under the CPU cover, I didn't trust myself to open that). Cap kit from Martin, of course! :) I put it together again after some suspence moments (no display at first, because I didn't reconnect the diplay board tight enough and such things). It looks stable now and I can listen to the radio though headphones (I'm restoring the Beovox 8000 at the same time, I can't test the Beomaster with them yet). I didn't do any adjustments yesterday and I'm wondering if it would make sense to do them today. (But... I'm so happy that it still works and I didn't do any bad mistakes! Very few caps were badly out of specs, but all were on the upper capacitance limit (mostly +50% at least) and three from the output stages are totally dead - no reading whatsoever connected to a ESR/capacitance meter after removal).
Offset output amplifier (the only thing I can measure without re-opening part of the Beomaster) measured according to the Service manual gives values of 25 mV (left) and 26 mV (right), but since more than half an hour this values are slowly going up (at turning on the meter reported something betwenn 5 and 10 mV). Now it moves very slowly, but I feel it's not totally settled yed.
The area over the display gets warm quite quickly - I don't think it's quicker than before the recapping, but still: should I check something? I would feel "better" if it would stay a bit cooler.
With headphones connected (Sennheiser HD545) I can hear 50 Hz hum on the right channel, not connected to the volume setting (doesn't change). (This is not a problem, actually: the headphone output was almost before the recapping, way too noisy).
If I turn the volume knob up and down with no input connected I can hear a small noise in the headphones at every "step" of the display. Probably no problem and probably impossible to hear with loudspeakers, unfortunately I don't have an oscilloscope and I cannot check the volume control offset as described in the service manual.
Almost last stuping question: if I decide to open the Beomaster again, in order to check the no-load current... Should I connect the multimeter to both sides of the same emitter resistor (plus right, minus left of the same resistor) or should i connect the meter like plus on R236, minus on R237, on the same side? Totally stupind question, I know...
Last question: is there a way to set the Beomaster 8000 to 240 V instead of 220 V? I never get less than 235 V here in Basel.
Ok... The Beomester has been on until now... Let's check the offset current again... Uhm: 26.7 mV (left), 28.8 mV (right). It's still going up. Does it make sense to open everything again and adjust the potentiometer 5R200 a bit? Right heatsink on the back (underside) hotter than the left one. I should definitely check that no-load current...
Thanks for any help - and here thanks again to Martin (dillen) for helping me through the process yesterday night.
Have a nice day!
Marco
