Hi Beoworlders,
The B&O bug has bitten again; this time in the form of a Beomaster 6500, Beogram 6500 CD and Beolab 6000s and Beo1000 and Beo4 remote controls. I now want to connect a Beolab 3500 to the Beomaster 6500 as simply as possible. I do NOT need a multiroom installation, also not in the future... and I would prefer to avoid the MCL to ML conversion. Before buying the Beolab 3500, I want to be sure that I can easily connect it.
I have read many forum entries for what feels like days. The B&O manuals for these components don't really answer my question and B&O's MCL Handbook confuses me (based on multi-room).
Here's all I think I need: a B&O adapter cable 6370298 or 6270295 (B&O reference from MCL Manual). This cable consists of two 3-pin MCL plugs wired into one 8-pin DIN plug. Connecting the MCL plugs to the Beomaster 6500 and the 8-pin DIN plug to the Beolab 3500 (looks like a Powerlink) should surely be all that is needed -or am I dreaming?
Specifically, please could you help me with:
1. Is the above connection correct?
2. If so, where can I obtain the adaptor cable?
3. Can I buy any model Beolab 3500 for this MCL connection to work or does it need to be an early model (or a LCS9000)?
4. If an early model Beolab 3500 is necessary, up to which serial no. can I buy?
I'd be very grateful for any help,
Regards, Normann
