Hi everyone,
My Beomaster 6500 was suffering from excessive noise from the transformer. It was the usual issue with the transformer shoulder washers disintegrating over time. After replacing the 8 washers and adding extra rubber washers the noise was greatly reduced. Further improved by adding more electrical tape on the transformer to completely cover the windings.
Whilst I have the unit cover removed, I was thinking about replacing 3 of the electrolytic capacitors related to the power supply which show signs of leakage.
I have the values 68uf 16v (C6) and 470uf 40v (C7) on the pcb labelled no 6 which also houses the two voltage regulators (TR3 & TR4)
There is a 1000uf capacitor on the small narrow pcb which houses the main fuse (2TA) Does anyone know what the voltage rating is for this capacitor? It is not clear from the markings on the capacitor.
Thanks in advance.
Gp
