My type 2702 is slowly but Shirley 👍being readied for use. Now, here's a non-electronic question:
The living room installation requires that the Beomaster 6000 be mounted a bit high in the cabinetry so I think I will want to tilt the unit forward a bit for better visibility. I think the t2702 left the factory with some sort of wire (metal rod) that is used for just such a purpose. Sadly, my unit doesn't have it. All that's left on the underside is three screws and bits of plastic - parts of the original mount. I'm pretty sure there should be four screws. There should be some sort of arrangement that allows the user to fold the bent metal rod up when not needed, and bring it down when used to prop up the rear of the unit.
Does anyone have a photo of this mounting gizmo? I'd like to get an idea whether I might be able to replicate this thing but I've never seen any picture or drawing of it. For all I know, it might not even be a bent wire prop, but that's all I can think of.
I realize that no one takes pictures of the rear end of their BM6000. No one? Anyone? Buehler? Buehler?
Jack
