Helllo,
picked up a Beomaster and Beocord 5500, CX100 and some sort of Beolink controller. Got a few issues:
I've plugged my phone in TP2/AUX In, which I believe is RCA 2 and 3 from the left, row closest to the backpanel (not row closest to the DIN ports). Speakers are connected to the upper row.
1) Result is the same if source is set to AUX or TAPE 2.
2) With my phone's output volume at max, volume level 28 on the BM produces - It's fairly low. At volume level 16 it's very background, at 40 it's OK but distortion starts (without really being loud). I'm 1 meter away from the speakers. Phones out works, pretty much the same description for the same volume settings. Also, speakers don't mute when I plug in the phones
3) The sound quality is rather underwhelming and sounds "wrong"
4) I've set treble and bass to 0
5) Loudness is on
6) When speakers connected to lower row, there is no sound
7) When I click mute on the front panel or the Beolink, there's a click but nothing happens to the sound. or any indication on the front panel
8) There's a physical bridge between RCA 4 upper and lower coloumn and RCA 5 upper and lower coloumn.
9) Is there any documentation on "Life with BM5500 and Beolink"?
10) The CX 100.. sounds like bass on top, treble in middle and mid-tone at the bottom???
Is this the normal operation for the BM 5500?
I don't have any tapes to test (with) the beocord.
Yes, I found this thread: /forum/general-discussion-and-questions/beolabs-8000
No, problem did not resolve itself magically for me :) And I do know what a RIAA converter is :)
