Hello all
I am new to this forum and hope for your help on my (new old) Beomaster 5500.
When I turn on the system the sound is very low with a lot of treble and no bass.
I can get the sound back into normal quality by increasing or decreasing the volume on the master control panel – it makes some loud scratchy noises and then everything is back to normal and works fine until I switch the system off.
The problem is mostly related to the tuner - when I start the system with CD or TAPE the problem is occurring some less. Also I cannot MUTE the system with the master control panel.
I guess this is all related – will there be a quick fix for this?
Thanks a lot for any good ideas.
Regards
Jesper
