Hello. My dad bought a used Beomaster 5000 (type 2321, probably from 1984) which according to the guy, who sold it for a friend, should work just fine - the very weak response to both of the remotes was excused with old batteries. The Beomaster only didn't work as it should, as it, as mentioned, has bad response to both of the remotes (MCP 5000 and Terminal 5000). The Beomaster doesn't send back signals to the MCP either resulting in a "No transmission" (IR-transmitters checked). I've read some threads about this on this forum and therefore ordered a new set of capacitors to replace the old at IR-board and the 100 µF-cap at the Power Supply - hoping it will fix the issue.
The Beomaster does, however, have other problems; the most serious one being the fact, that the only button working on the flip-down panel is the "Store"-button. I just today replaced the silly, partly broken,thin cable to the flip-down panel with a decent flat cable - unfortunately without any luck. I simply need the flip-down panel just to be able to switch the "Loudness"-button off, but I simply don't know where the problem is?
The last problem is that there is no sound from the Speakers 1. It does, nonetheless, play in the headphones, if I plug in a pair. There is also sound if I plug the speakers into the Speakers 2 speaker-exit. I've tried the mute-button on the MCP5000 and I can hear the relay "clicking" - no sound, however. Having measured the speaker connectors, I know they are fine, and the soldering looks fine. Could it be a relay somewhere?
I hope you guys can help me. Thank you in advance!
Stefan
