Dear Gerard,
How did you clone the Crucilal MX500?
And does it still works fine and fast? No issues?
Dear Gerard,
Maybe I was just lucky but my Beomaster 5 works perfectly well on a daily basis using a cloned 1TB Crucial MX300 for more than three years now, no booting- or compatibility issues whatsoever. I have no experience with the MX500 vs the MX300 but it may well be that there is a HW compatibility issue keeping in mind the very outdated hard- and software (Windows XP embedded..) so I would stick to the MX300 as the system is not equipped to benefit from a more recent SSD hardware. I have not increased the size of the disk (my Beomaster 5 was running on a 1TB HDD) and this seems to be a common source of problems described in this forum.
Good luck, Robert🙂
Same for me. And my system is on all the time.Maybe I was just lucky but my Beomaster 5 works perfectly well on a daily basis using a cloned 1TB Crucial MX300 for more than three years now, no booting- or compatibility issues whatsoever. I have not increased the size of the disk (my Beomaster 5 was running on a 1TB HDD)
MX300 1Tb works for sure, I have it for 3-4 years and never had one single problem (like what I experienced with Samsung or other drives ). The issue maybe with cloning - I have used EASEUS free cloning software, it has few options, as far as cloning method is concerned, I do not remember exactly what option/method I used, but it worked on two system with MX300 500GB and 1Tb drives.
Hi! I have a 500gb Beomaster 5 and I want to do the SSD upgrade. I have read all the pages in this thread and there is two SSDs that is being mentioned as the right ones. MX300 and MX500. But they doesn't seem to be able to buy today. What other 500gb SSD will work for me?
Thanks!
according to another entry in this blog, the Sandisk 3D Ultra 500 uses the same controller as the Crucial MX300 but I have not tried. This product still seems to be available. Please let us know whether this is successful. best, Robert
Hello, i will get a SunDisk ultra 3d 1TB tomorrow and i will clone it with the B&O software tool. I understand it so that i have to replace the original HDD with the SSD and then boot up with the b&o tool and then clone the entire HDD, is that the right way ??
Thanks for any tips
Thanks for any tips
