Beomaster 4400 restoration help
I sent you a PM with photos. I have reccaped and fully working BM4400 (kit from Dillen).
Thank you - I will look into that.
Check for cracked solder joints at- and around the relay.
Check that the relay is working.
Check for presence of any DC on the speaker outputs.
You say you have adjusted the no load current........yet have no power at the 35v rail? where are you trying to measure the 35v....
Craig
