So now we have proof of an extra-tantalistrial situation! ❓😂
Far from all production changes, sub-revisions, aftermarket modifications and territory specific versions are equally well documented.
Some aren't at all, which makes putting together the kits quite a task and feedback and information from owners valueable.
I agree they look original, but I cannot tell you exactly why one tantal was added across TR18 C-E and another to decouple the supply to part of the IF.
The latter could be to counter for a particularly troublesome batch of IF Amp ICs (OpAmp CA3012). I can't say.
Perhaps that could explain both of the tantals, really.
Of course I will look into this and see, if the kit should be updated with this info, as I always do when new information turns up.
Can you tell me the serial number of this Beomaster 4000?
I will happily send two new tantals to you, just say the word, but if on the bench here I really wouldn't worry about leaving both of them in place.
