I was picking up some Beovox P45's from a 2nd hand dealer when I saw the BM4000 lying in a corner. "How much for that" was answered with "It won't even turn on, take it if you want it".
Of course it went home with me and it is still a work in progress.
- Both fuses were blown (that could explain why it wouldn't turn on)
- The main rectifier was dead and the safety cap as well - replaced
- After that fix got sound on right channel, power light works, signal strength meter works, tuning lights work, stereo light blown
- Radio works but skips like crazy - will sort that once the left channel is working
- PCB 8002135 (small one with voltage divider resistors) had a major short, parts of the circuit were burnt off - fixed that
- Was not getting correct output voltages on PCB 8002135, replaced all divider resistors and now sorted
- Signs of capacitor leaks on left channel main output PCB - replaced all orange caps on all boards
- Replaced the main caps
- Left channel had been worked on previously on main output PCB, ceramic resistors had wrong values, replaced left and right channels
- Replaced all the trim pots on the main output board
- Getting 12mv on right channel
And this is where I need help. I have the BM4000 service manual, can solder and have the most basic electronics knowledge. Have multimeter but no fancy oscilloscopes and such.
I am getting 65-70 volt readings all over the left channel towards the output side and cannot figure out where it is all coming from. Getting 70v from the Darlingtons and the small transistor tucked behind the Darlington PCB.
There are two resistors (100ohm #583 and 330ohm #570) that instantly turn to toast every time I replace them.
Would greatly appreciate any help with looking for likely culprits that are causing the 70v flooding of the board. I know the red/white wire supplies power to the board at 70v but whatever is supposed to drop it down to the 35v stage is not working.
Thanks to everyone that ever posted on the Beomaster 4000, your advice and solutions have helped me get this far.
Best regards
Anton
Model:
Main PCB, can see the two transistors that keep burning - (100ohm #583 and 330ohm #570)
