Hi Everyone,
so I started using my Beomaster 3400 but a hum problem has developed and perhaps anyone here would have some suggestions if there is anything that I can do with this...
I started noticing a hum through the speakers. It is not there when I turn the receiver on, but at some later point I can hear it when there is no music or the music is quiet. I did some tests and a couple of times I turned the BM on, it was completely quiet and the hum kicked in suddenly about 30 seconds after power up. Everything but the speakers was disconnected from the the BM. Also, it gets worse in the 4-channel mode - when either of the MONO/STEREO/MATRIX button is depressed the hum is significantly lower than when none of these 3 buttons is depressed.
When I listen to music the hum, if it appears, usually kicks in 60-90 minute after power up. There was however one time when it went 4 hours without the hum kicking in.
I made a short video of it, in case any one has 51 second to spare: https://www.youtube.com/watch?v=d-evkZ6NHng&feature=youtu.be
In any case: is this something normal with these? Should I take it in for a service? Or perhaps could it be something with my setup? (I did make sure no ground loops and such are present). The receiver went through a complete recap and refurbishing a few weeks ago -- should I complain about this thing to the guys that has it in for service?
There is another issue with start up, several times after turning the BM on by pressing there was a several second pause when nothing happened and the receiver came to life some 10-15 second later. Could these two issued be connected?
As always, I'll GREATLY appreciate suggestions, I really love the way this things rocks and want to keep it in good shape.
Piotr
ps. sorry for another long post...
