Beomaster 3300 type 2957 Help Needed
It's been awhile, but I just got a Beomaster 3300. As usual if you get something for free there is always a catch🙂
Anyway, this receiver doesn't want to co-operate and refuses to start up.
The standby doesn't light up, instead the bars of the FM fine tuning light up. That's all.
No button responds, No stand-by light, No sound. Only FM fine tuning bars. See attached picture
Fuses are fine. I could measure 33 volts on the power capacitors
Does anyone have a clue or can point me in a direction?
Thanks,
Richard
Anyone?
Is the 5V supply up for the processor?
Hello Martin,
Nice to meet you again.
I"ll measure it.
Hello Martin,
I could measure 5 volts on IC1.
Hello Martin,
We are talking about the small voltage regulator 7805 (IC1), which supllies 5 volts. This one measures correct.
Are the fine tuning bars an indication for a fault?  I couldn't find it anywhere.
The tuning discriminators are driven by the tuner. The other lamps are driven by the processor board.
Check all voltages to the processor board - measure the voltages on the processor board and make sure the ground connection for the board is fine.
Check if the processor is running. If not running - check the reset signal etc.
Martin, thanks. I understand.
I'll make all measurements asap and come back with my findings.
Hello Martin,
I checked the voltages of many measuring points.
In the reset part, there is TR35 and TR36. Both are about 4,5 volts too low ( 5,5V and 0,4V instead of  9,7V and 4,7V)
The rectifier gives 24 V, which is correct.
If I read the diagram correct, the only parts which could be defect are the 2 resistors R92 or R93, but most probably Diode D24 as the difference in voltage is 4,5 volt. This is just the voltage to the direct linked IC1
Can you agree with my reasoning, or do you have an alternative?
