Hi Beoworld
I recently bought a Beomaster 3300 with a set of RL35 speakers. I actually bought the set to get the speakers, which are in good condition. Price 45 dollars.
The problem is the Beomaster 3300, which do not power up but turns on some of the lights. I find it a shame to throw it away and have started a mission to repair it. I hoped to find some help at this forum, but I have not been able to find what I was looking for, despite my thorough search of the current and archived threads.
It started out with no lights at all. After resoldering TR46, 39 and 40 some lights started to glow.
For now I have checked the following:
Fuses - which are ok
Power draw - which is approximately 5W (starts at 10W and stabilize at 5-6W)
Switch seems ok but is not getting any voltage - less than 1V
The lights that turns on are most of the volume lights and if i look very closely I can see some of the function lights as well.
Checked the transformer - Voltages at the secondary side(seen from the above)
Left side coil:
- between black and gray = 25,5V
- between black and brown = 10V
Right side coil:
- between black and brown = 9,8V
Checked the transformer again with the gray and brown wire de-soldered from the secondary side (both coils)- Voltages at the secondary side(seen from the above)
Left side coil:
- between black and brown = 9,7V
Right side coil:
Powerdraw is now 2W (with the wires detached)
tools at my disposal:
- AC/DC power supply (24volt/24volt)
- multimeter (Ohm/amps/voltage + transistor pnp and npn test)
- Soldering iron
- schematics (for beomaster 2200, 3000 and 3300)
Would any of you have any idea what could be wrong with my beomaster or any hint to where my next step should go?
Are there any typically faults I should consider?
Any help will be highly appreciated!!!!
BTW: Of other side projects, I am currently refurbishing a set of RL140 and a set of CX100. Both need needs new foam surrounds.
Thanks in advance, and thanks for an awesome forum!
