Hi Martin,
I measured the IF signal at the TR8 collector (finally I get maybe a bit of a grasp how a FM tuner is working...;-). I get a ~5.8V 10.8MHz signal when tuned into a local station (signal strength: ~4 on the meter). Then after the filter (#101) at point D this signal vanishes...all that is remaining is a very weak 30mV 10.8MHz signal. This explains why there is nothing going on at the base of TR9. Does this mean the filter has a problem? Thanks!
Rudy
