Pete wrote:
Signal GND to Chasis = 90 k Ohms
Signal GND to GND on Power Supply = 0.5 Ohms
I notice on the PCB there are two holes drilled, one on signal GND and the other on Power supply GND... Could the GND issue be the cause of all these components frying? I wander, when I construct the new board should I merely connect signal GND to Power GND to test the new board?
Login to view image
0.5 ohms between both ground planes at the power supply is normal because that's where they are centrally connected. 90k at the board is possible because of various components that link the power path and signal path.
Those 2 holes between signal GND and power GND look like a precautionary design measure. At the time of board design they were not sure if power GND/signal GND separation was "worth it". But ultimately they found that the separation was benefitial in terms of noise rejection, so they kept the planes separated, which forced them to run the extra wires from power supply to amplifier.
When you construct the new boards, you should retain that separation, or else you'd create a ground loop when connecting the preamp and that might cause a hum or other noise. For offline testing of this new board you can - actually must (!!) - connect those 2 GND points at the amplifier board, but when you connect the preamp, the jumper between power GND and signal GND must be removed.
In the original design the startup circuit R1/C1 acts on both channels at the same time, but in your new design you should add the same components to each channel. Make it part of the power path (and not the signal path as done in the original!!). This way you have 2 identical, interchangeable boards for the 2 channels and you don't have to worry about modifications for offline tests!
