Hello from a new member and long time happy lurker (-:
Our Beomaster 1700 (type 1701) has been in various lofts for 20years. Spurned on by the CV19 lockdown here in the UK I’ve been trying to repair the amplifier board. The loudspeaker cable on the left channel was shorted and fried a few components.
I’ve read as much as I can find on the web (manuals etc) yet found your forum the best place going forward. There are a few issues that I hope members can help me with:
As suggested in previous posts i replaced all burnt-out parts (resistors, a variable resistor, a diode and all transistors) and electrolytic capacitors all with original tolerances. nb, the 0.39ohm 1W wire-wound resistors were only available as ceramic 5W at the time.
The Heat-Sinked TE 1088 and TE 1089 are now obsolete (only available as ‘used’ on ebay) so I looked up BDX33a/34a as replacements only to find that they have been replaced by BDX33c/34c which seem to have slightly different electrical characteristics but purchased them anyway as there seemed no other option.
In the manual, the VR1k resistor sets the 'no load' current. I set this resistors' trim as close to the original one that i took off the board. Disconnected Speakers and input connector from pre-amp stage and turned the mains supply on….
Within two seconds the replacement 0.39 Ohm 5W ceramic wire-wound resistors glowed (located between the emitters on BDX 33c/34c. There was a burning smell from those and the 27 Ohm 1/8W resistor connected to MPS A05 and MPS A55.
Maybe a few things caused this
1. The variable resistor 1K value needs to be changed
2. The Ceramic 0.39 ohm 5w resistors were the wrong type.
3. The replacement BDX33c/34c are so different that a few other resistors values need to be changed.
4. Having no audio signal load to the board may have also caused the ‘thermal run-away’
I have now ordered lots of 0.39 ohm 2w wire-wound resistors (original spec), a supply of various fixed resistors and variable resistors - further £20 spent (-:
Q; How can I check the 12mV (maybe it’s different now?) across one of the 0.39 Ohm resistors without blowing everything again?
Q; Is there a formula to work out alternative values of resistors and mV value in this amplifier stage - due to change in output transistors?
Q; How can i test transistors without an oscilloscope or wave generator, i only have a multimeter with hFE pnp/npn holes?
Q: Is there anything above that I’ve overlooked?
The B&O was a gift from my uncle in the late 80’s - My uncle died last year, he loved his music and various B&O through the years and it would be lovely to get this up and running as a tribute and for it to take pride of place in the home office.
I haven’t done much in electronics since the 90’s so If I can’t repair this amplifier board I’ll consider trying to find a power amp stage that can run on a single 50 volt supply and hide it in the case! I really hope this isn’t my only option.
I hope to attach images:
Output stage diagram for one channel - The ‘Red’ squares indicate parts that burnt-out when speaker cable was shorted many many years ago
Photo of board as it is now) while waiting for more replacement parts to arrive after 1st attempt - R212(vR) - R214 - R221 - R222 - also showing some of the old components removed from original shorting mishap circa 1990's
Electrical Characteristics of BDX 33a/34a (B&O’s suggestion for replacement to TE1088/9)
Electrical Characteristics of BDX 33c/34c (interwebs suggestion for replacement to BDX 33a/34a)
Any help would be warmly received - Thank you in advance Login to view image Login to view imagee.
