Gentlemen, I have your Beomaster 1600 update.
Spent a second day clearing this incredibly dirty Beomaster 1600. Layer after layer of grime revealed new information about this Beomaster.
Took the two control adjustment pulleys off and properly cleaned the rollers, which made a huge difference.
Cleaned the tracks (again) on both sides of the belt paths on both panels and adjusted the belt tensions. Real progress here and all clutches perform perfectly except, and wouldn’t you know it, the volume control clutch; which slips. Disappointing, but Martin has a kit for this so no matter.
Next was the switch which was still connected to the cable from the power supply (I missed this small detail somehow) and found the switch was WAY to bulky in movement for the other controls to move. I thought about taking the switch apart, but decided to see if the amplifier would power-up, set the switch to ON, grounded it and plugged in the Beomaster.
Logic would have it that if the previous owner was concerned with the switch that the amplifier worked….. well not this time as the Beomaster remained helplessly dark and silent.
Time to get out the multi-meter and check the fuse…. it was good.
Now what is needed is to become reacquainted with my trusty multi-meter and test to see if there is power to the switch, if so, the power source is OK. Then check to see if there is power after the switch…. but like Søren experienced with his equally dirty Beomaster 4400, I was exhausted and decided to call it a day.
Disappointed for sure, but we’ll see where this all leads. At least the other gift Beomaster 2400.2 was a complete success and oh boy, did it ever come out better than expected.
Jeff
