Is that a trick question? 😠 😜
If you pick just any transistor with arbitrary gain values and voltages, one would surely expect that the output is different than with original transistors, don't you think? Do you think that the B&O guys picked the BC547B and the BC182C for this opamp TR104/105 just to annoy you? (see footnote)
I would guess they did it on purpose and for some technical reason. Either they actually calculated the amplifier design or - more likely - they used a standard design and adjusted it to their needs.For today's standards, this is a run of the mill class AB amplifier with feedback to the driver stage.
The base of TR105 is the non-inverting input of this opamp and carries the feedback from the final output signal. The base of TR104 is the inverting input and it carries the audio input signal. Changing hfe of those transistors will surely have an effect on the characteristics of the amplifier. If you must replace them, then use equivalents with similar characteristics.
Using 30V transistors instead of the original 50V ones is not a good idea. It may work if all other components are ok, but if TR108 shorts for whatever reason this will also send TR104 and 105 to their graves. B&O chose 50V versions; so, use the same or bigger.
PS: Sorry for my initial sarcasm. I just find it a bit strange that you take the effort to hand-match modern transistors, but then just replace the original models with some other type without considering their function in the circuit.
The general rule in electronics is: If you need to replace obsolete transistors, you pick models that are as close as possible to the original. This way you have a high chance of success without having to analyze the whole circuit in detail.
If you're good in electronics design, you can change the original transistor specs quite a bit based on what's going on in the circuit. It does leave you though with the risk that you're overlooking something that the original designers had already identified as a problem and fixed in their commercial product.
