Hello all,
is there a way to have the actual temperature of each room displayed as the current temperature in the beoliving app? My approach is the following: I have installed in each room a temperature sensor (fibaro) and I have created for each room a dummy no off thermostat. I made a macro where every half hour the bli asks the temperature value of the fibaro sensor and it is diplayed by the dummy thermostat as temperature.
So far I manged to get the temperature value of the fibaro sensor with no problems but it looks that the temperature of the dummy thermostat can not be set by the user. I am using the following code:
function(event, engine)
local Temp_query=engine.query("House/Family Room/_THERMOSTAT_SENSOR/Temperature/")
local temp = Temp_query[1].get("_TEMPERATURE")
engine.fire("House/Family Room/THERMOSTAT_1SP/TEST/SET TEMPERATURE?VALUE="..tostring(temp))
end
If anyone has any idea don't be shy!๐
