BeoLiving news & support from Khimo!
Hi Carolpa
I really works now - thank you for your great work.
One more minor thing.... is it possible to change this code a bit?
The Ikea values are kind of reverse, so if the Value says 80% - it is 80% Open, not down/closed, which had made more sense to me
"direction=true
      else
        direction=false
      end
      if direction then
        nr = nr + 5
        if nr>=100 then
          nr=0
        end
      else
        nr = nr - 5
        if nr<=0 then
          nr=100
        end"
Hi Carolpa
"direction=true
      else
        direction=false
      end
      if direction then
        nr = nr + 5
        if nr>=100 then
          nr=0
        end
      else
        nr = nr - 5
        if nr<=0 then
          nr=100
        end"
Hi Carolpa
"direction=true
      else
        direction=false
      end
      if direction then
        nr = nr + 5
        if nr>=100 then
          nr=0
        end
      else
        nr = nr - 5
        if nr<=0 then
          nr=100
        end"
  if tonumber(event.parameters()["OFFSET"])>=1 then
        direction= true false
      else
        direction= false true
      end
Hello all,
is there a way to have the actual temperature of each room displayed as the current temperature in the beoliving app? My approach is the following: I have installed in each room a temperature sensor (fibaro) and I have created for each room a dummy no off thermostat. I made a macro where every half hour the bli asks the temperature value of the fibaro sensor and it is diplayed by the dummy thermostat as temperature.
So far I manged to get the temperature value of the fibaro sensor with no problems but it looks that the temperature of the dummy thermostat can not be set by the user. I am using the following code:
function(event, engine)
  local Temp_query=engine.query("House/Family Room/_THERMOSTAT_SENSOR/Temperature/")
  local temp = Temp_query[1].get("_TEMPERATURE")
  engine.fire("House/Family Room/THERMOSTAT_1SP/TEST/SET TEMPERATURE?VALUE="..tostring(temp))
end
If anyone has any idea don't be shy!๐Ÿ˜
If you use a Home Assistant server, it's very easy to pull the temperature via this into the BLI, to show in the app:
https://www.home-assistant.io/integrations/generic_thermostat/
I have cordless Aqara in every room, for this feature:
https://www.amazon.com/Aqara-WSDCGQ11LM-Temperature-Humidity-Sensor/dp/B07D37FKGY
Hello CTR I am not using any home assistant๐Ÿ™
Today's dumb question (yes me again) ๐Ÿ˜ I've noticed since the last two updates (maybe just coincidental) that my macros that fire when they are before sunset seem to no longer work.
I have my lat/long and time zone all correct and it shows the correct time.
Any timed Macro works perfectly it's just if I define a before sun set time, e.g., -90 shows as
Main/global/SYSTEM/Clock/
STATE_UPDATE?bss=-90
Any idea on the obvious thing I'm not doing?
Hi benjnz,
We've been working on a fix of some sunset and sunrise issues. If you like you can write to us to support@khimo.com with your BLI serial number and we can enable to you a firmware version in testing with these fixes.
Hi Carolpa - Hi everyone.
I hope B&O and Khimo works towards making the Beoremote Halo a Beotime 2.0!
Can we do this ourselves via LUA?
I imagine:
1.ma button on Halo with toggle Alarm On / Alarm Off
2. Possible to set alarm time on each day of the week in LUA
3. Turn on e.g. TuneIn on one's AV renderer.
Thank you for your time
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
