Hallo again
Thank you for your reply.
Unfortunately, this results in an error!
Hallo again
Deleted
it was just a long shot. But it would be interesting to know what the error says.From learning point of view, I will have to look to the Home Assistant options.Hallo again Thank you for your reply. Unfortunately, this results in an error!
I'm in the middle of building a new home set-up from scratch and so far i have purchased the following components:
Now i'm looking at expansion. My wishes are:
- Hue lamps for all rooms + Hue Bridge
- Honeywell Evohome thermostats system for all rooms
- Outside camera system + Video doorbell.
For the latter im asking you advise. Are you guys using outside camera's and a video doorbell and can you please react which ones works seamslessy with the BLI?
If the connection between Home Assistent and BLI is set correctly, the instruction should be:Hallo againThank you for your reply.
engine.fire("your_area/your_zone/SHADE/BLI_Resource_name/LOWER")
engine.fire("your_area/your_zone/SHADE/BLI_Resource_name/RAISE")
engine.fire("your_area/your_zone/SHADE/BLI_Resource_name/SET?LEVEL=10")
try these.
Any onvif ip camera will work. I would go for a POE camera as it saves hassle. I use a nvr as well. I use hikvison. There are better camera”s for less money as long as it supports onvif you should be okDoorbell. I use doorbird. Works fine BE SURE TO WIRE. Any doorbell which is not wired is stupid. Takes way to long. Doorbird is also expensive and low resolution I have bought this in 2018 could be there is a better system know.Hue will work out of the box and Honeywell as well in Europe.Hope it helps.Chucky.I'm in the middle of building a new home set-up from scratch and so far i have purchased the following components: BLI with Pro software 1X BS Essence MK2 connected to 2X BL3 in the kitchen 1X BS Essence MK2 connected to in an active in ceiling speaker in the bathroom 1X BS Core intregrated to my BV14-55 with 2x BL3 in the living room Now i'm looking at expansion. My wishes are: - Hue lamps for all rooms + Hue Bridge - Honeywell Evohome thermostats system for all rooms - Outside camera system + Video doorbell. For the latter im asking you advise. Are you guys using outside camera's and a video doorbell and can you please react which ones works seamslessy with the BLI?
Hello everyone,
Just wanted to let you know that B&O are aware of the issue that causes the Halo connectivity problems with the BLI, and they are working on the fix. We will let you know as soon as we have news on this front 🙂
Thank you Carolpa
The function works perfekt now. So if I set the Halo to 25% shades, it set the shade på 25%.
But the Shade logo on the Halo goes back to show 100% - do you have a great solution??
Have a fantastic weekend
CTR
Maybe I do😕Thank you CarolpaThe function works perfekt now. So if I set the Halo to 25% shades, it set the shade på 25%.
CTR
Now I know the LEVEL settings work I will look into using the Halo wheel.
+ using the WheelBut the Shade logo on the Halo goes back to show 100% - do you have a great solution??
make two Resources 1) Fired (bbolean) and 2) No (integer)
make two events for the Halo Shade button 1) button pressed and 2) wheel turned
then use the next code:
function(event, engine)
-- make Resource Variable Fired (Boolean)
-- make Resource Variable No (Integer)
local fired_query = engine.query("Upstairs/Study/VARIABLE/Fired")
local fired = fired_query[1].get_boolean("VALUE")
local shadeLevel=0
local direction
local nr_query=engine.query("Upstairs/Study/VARIABLE/No")
local nr = nr_query[1].get_number("VALUE")
if nr==nil then
nr=1
end
if not fired then
engine.fire("Upstairs/Study/VARIABLE/Fired/SET?VALUE=true")
if event.parameters()["OFFSET"] then
if tonumber(event.parameters()["OFFSET"])>=1 then
direction= true
else
direction=false
end
if direction then
nr = nr + 5
if nr>100 then
nr=100
end
else
nr = nr - 5
if nr<0 then
nr=0
end
end
shadeLevel = nr
engine.fire("Upstairs/Study/VARIABLE/No/SET?VALUE="..tostring(shadeLevel))
engine.fire("Upstairs/Study/Halo remote/Beoremote Halo Study/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810383&TEXT="..tostring(shadeLevel))
engine.fire("Upstairs/Study/Halo remote/Beoremote Halo Study/SET_WHEEL_VALUE?BUTTON=497f6eca-6276-4993-bfeb-000000810383&VALUE="..tostring(math.floor(shadeLevel*100/100)))
engine.fire("Upstairs/Study/SHADE/your_shade/SET?LEVEL="..tostring(shadeLevel))
end
end
engine.fire("Upstairs/Study/VARIABLE/Fired/SET?VALUE=false")
end
Note: I deleted "--" previous shown incorrectly in one line.
