Looking at the Monitor & Loggings I would investigate 2 settings:
the wifi connection settings of your router (2.4 or 5GHz etc).
the wifi settings of the Halo.
The BG4000 is connected to a BLC.
I assume connected to AUX IN of BLC, coming from a preamp between BLC and Beogram 4000? It is amazing that is shows in BLI/Halo. 👍
I have tried different ways to get the track number but with no success.function(event, engine)
local core = engine.query("your_area/your_zone/AV renderer/your_BLC")
local Details_now = core[1].get_string("nowPlayingDetails")
local track_pos=string.find(Details_now, "track number:")+13
local track=tonumber(string.sub(Details_now,track_pos,-1))
engine.fire("your_area/your_zone/Halo remote/your_Beoremote Halo/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT="..tostring(track))
end
Thanks a lot Carolpa!🙂
Hallo,I am completely fed up with it.
I do not know the source of your Halo-wifi problems, but are reassured I use two Halo's wifi connected to my network to my satisfaction. Both do not give more or less problems with wifi then other wifi connected devices; which are minor, occasual occuring problems.
Just an idea: did you try changing upnp settings/blocking of your network? Do you use a Fingbox?
Hi Khimo Team!
Could you add a driver for Ikea Tradfri lights and Blinds, to work directly with the BLI?
Hi Carolpa
You are our LUA wizard :)
Do you or someone, who has a LUA code, or a guess at such, so I can control my IKEA curtains in percent via Halo WHEEL_TURNED.
The Ikea curtain comes via Home Assistant, but does not work as I want at the moment.
1. Sal/Soveværelse/SHADE/TRADFRI blind - LEVEL=0 & ONLINE=true
engine.fire("1. Sal/Soveværelse/SHADE/TRADFRI blind/LOWER")
end
Thank you :)
What if:Do you or someone, who has a LUA code, or a guess at such, so I can control my IKEA curtains in percent via Halo WHEEL_TURNED.The Ikea curtain comes via Home Assistant, but does not work as I want at the moment.
Resources States:
end
engine.fire("Sal/Soveværelse/SHADE/TRADFRI blind/LEVEL=10").
engine.fire("Sal/Soveværelse/SHADE/TRADFRI blind/LEVEL=50")
does this work or do you get an error?
Deleted
