BeoLiving news & support from Khimo!
Looking at the Monitor & Loggings I would investigate 2 settings:
the wifi connection settings of your router (2.4 or 5GHz etc).
the wifi settings of the Halo.
Carolpa wrote:
The BG4000 is connected to a BLC.
I assume connected to AUX IN of BLC, coming from a preamp between BLC and Beogram 4000? It is amazing that is shows in BLI/Halo. 👍
Carolpa wrote:
Tassos wrote:
I have tried different ways to get the track number but with no success.
function(event, engine)
  local core = engine.query("your_area/your_zone/AV renderer/your_BLC")
  local Details_now = core[1].get_string("nowPlayingDetails")
  local track_pos=string.find(Details_now, "track number:")+13
  local track=tonumber(string.sub(Details_now,track_pos,-1))
  engine.fire("your_area/your_zone/Halo remote/your_Beoremote Halo/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT="..tostring(track))
end
Thanks a lot Carolpa!🙂
Dag Carolpa,
I am completely fed up with it. I have never used wireless with B&O only on a BS1 in the garden and for a reason.
I have looked at my settings and I cannot see anything strange on it nor can I change the bandwith as I use products who support 2.4 Ghz like Alexa.
I am going to pull a wire and good luck to any who use it as a wifi remote. I use my br1 for curtains lights and skylights and it works from 2018 onwards. Bluetooth and IR. I have 8 BR1 and 3 ipads in the wall never had connection issues. No way I am going to replace iPad’s or add any Halo for wireless. The Halo in the hal is completely useless as it reconnects every time I come in the neighborhood and if it is running it shows the BS KItchen Core and i have to push 30 buttons before I see my BLI menu.
Thanks anyway,
Chucky.
Hallo,
I do not know the source of your Halo-wifi problems, but are reassured I use two Halo's wifi connected to my network to my satisfaction. Both do not give more or less problems with wifi then other wifi connected devices; which are minor, occasual occuring problems.
Just an idea: did you try changing upnp settings/blocking of your network? Do you use a Fingbox?
Hi Khimo Team!
Could you add a driver for Ikea Tradfri lights and Blinds, to work directly with the BLI?
Dag Corolpa,
Everything works like a charm, I run 500mbit wireless and hired someone to install it. I will wire this one and look in the year if I am going to buy another and get somebody in to change the router. I run Ubiquiti with 6 switches and 5 AP”s.
Thanks Carolpa, still appriciated!
Hi Carolpa
You are our LUA wizard :)
Do you or someone, who has a LUA code, or a guess at such, so I can control my IKEA curtains in percent via Halo WHEEL_TURNED.
The Ikea curtain comes via Home Assistant, but does not work as I want at the moment.
Resources States:
1. Sal/Soveværelse/SHADE/TRADFRI blind     -      LEVEL=0 & ONLINE=true
  engine.fire("1. Sal/Soveværelse/SHADE/TRADFRI blind/LOWER")
end
Thank you :)
Resources States:
end
What if:
engine.fire("Sal/Soveværelse/SHADE/TRADFRI blind/LEVEL=10").
engine.fire("Sal/Soveværelse/SHADE/TRADFRI blind/LEVEL=50")
does this work or do you get an error?
Deleted
