BeoLiving news & support from Khimo!
Seanie_230 wrote:
Hello all
I am using essential mode.
Any idea how to move the scene at the bottom to the top?
The Halo shows it at the end of the list and I would like to get it to the start of the list by moving it up.
I believe you can only edit the Halo's menu in pro mode. When in pro mode, you do this by going to the Interfaces tab. It's well worth upgrading to pro mode -- especially if you're used to the control you had using a BLGW.
BTW, Khimo really does deserve the benefit from us upgrading to Pro mode. Their support has been amazing!
Agree
If available the way to change the order:
1. goto Interfaces / Zones setup
2. choose the zone
3. click and hold the three lines and drag the line to the position
It seems though also that the original order of the Scenes are defined by the succession the Virtual Resources were programmed. Maybe by re-entering the scenes in the appropriate order will do the trick.
beojeff wrote:
Khimo-
Thank you for your message regarding the loss of connection between the BLI and Halos. Actually, only the wall version of the Halo has the option to be wired to the network. The desktop version of the Halo does not have an ethernet port. All of my Halos have always been wifi only.
I have done a factory reset on all of my Halos and the problem keeps recurring.
I came home today and my living room Halo again no longer shows the BLI pages.
Thanks,
Jeff
Same issue, I can wire but it is a remote. I lose connection at least 4 times a day. B&O logo etc. I am waiting on a solution so I can buy more halo”s
Chucky
chucky wrote:
Same issue, I can wire but it is a remote. I lose connection at least 4 times a day. B&O logo etc. I am waiting on a solution so I can buy more halo”s  Chucky
did you look if there isn't a Lua Macro with "fatal" errors or loops?
Happy New Year dear BLI/Khimo team and all forum BLI experts and lurking enthusiasts! 😁
I saw Beogram 7000 and Beogram 4000 integrated with Halo and (I assume) BLI in Carolpa's post on the page 14. What is needed to achieve that? Any way to do it with BLC NL/ML or a Beomaster is needed too? Merely hoping for a remote "Start/Stop" fumctionality. 👍
The BG4000 is connected to a BLC. The BG7000 is part of my Beosystem 7000 connected with a T1611 to a BLC.
The Halo buttons are programmed/setup with BLI.
The BG7000 button is replaced by a Beosystem 7000 button. This button toggles between choosing CD or PH. And Yes the BG7000 starts to play if a record is placed. To integrate a stop also should be possible.
same wishes to you
This is what i see in the log file:
2022-01-02T09:44:54.309872+01:00 bli server: B&O Halo remote (26070): 33286849: aliveMonitor: keepalive: send a PING
2022-01-02T09:44:56.294240+01:00 bli server: B&O Halo remote (26070): 33286849: aliveMonitor: timedout, notifying
2022-01-02T09:44:56.303549+01:00 bli server: B&O Halo remote (26070): 33286849: aliveMonitor: keepalive: timeout: table: 0x517c47c0 OPEN
2022-01-02T09:44:56.313167+01:00 bli server: B&O Halo remote (26070): 33286849: Closing connection, no activity in last 62 seconds.
2022-01-02T09:44:56.322727+01:00 bli server: B&O Halo remote (26070): 33286849: _scheduleConnectionRetry: starting wakeup timer 10s for msg:aliveMonitor: Connection is dead, retrying in 10 seconds
It keeps dying on me and as soon as I see the proximity sensor it keeps popping up with the logo. I have no macro running
On the error history:
2022-01-01T02:23:22.265469+01:00 bli server: B&O Halo remote (26070): 33286849: socket error: Unreachable host
2022-01-01T02:25:53.663522+01:00 bli server: B&O Halo remote (26070): 33286849: socket error: Unreachable host
2022-01-01T02:32:54.229901+01:00 bli server: B&O Halo remote (26070): 33286849: socket error: Unreachable host
2022-01-01T02:43:04.753775+01:00 bli server: B&O Halo remote (26070): 33286849: socket error: Unreachable host
2022-01-01T02:46:31.520333+01:00 bli server: B&O Halo remote (26070): 33286849: socket error: Unreachable host
2022-01-01T02:50:01.453135+01:00 bli server: B&O Halo remote (26070): 33286849: socket error: Unreachable host
On macro's:
No events or loops.
Northing....
Halo on accespoint active.....However only for 4 hours and 53 minutes
It is a very expensive paperweight, I cannot use this. I will contact my dealer for a wired version I supose.
Chucky
chucky wrote:
No events or loops.
How long did you wait? You should always see messages after some time........
Under logs I see more then 1000 lines, it connects to 8 thermostats 3 hue bridges Etc.
But I have no loops in macro”s. I have had this ones it simply kills itself as it is crowded enough with everything I have connected.
On the log I have filtered Halo:
No connection….
As soon as I arrive it wakes but I do not wish to wait 30 seconds to start up.
