Khimo-
There are some stability issues that need to be looked into regarding the BLI and Halo remotes. The BLI keeps loosing its connection with the Halos and needs to be power-cycled to regain the connection. I've reserved static IP addresses for the BLI and the Halos, yet this problem persists. Also, it would be nice to have a reboot option in the BLI configuration interface.
The reboot option is high on my list as well. As far as the stability of the connection is concerned I am encountering zero problems. My Halo is always connected except if I restart my router, in which case (sometimes) it gets the previous IP+1 (192.168.1.180 before the restart, 192.168.1.181 after the restart). Restarting the BLI solves the issue. I am using the velop system of linksys with 2 mx5300 nodes. One as a router and the other as a child node. Wi-Fi coverage is excellent throughout the house and Wi-Fi speed is very fast especially to Wi-Fi 6 enabled products. I don't know if this is of any help to you Beojeff.
