BeoLiving news & support from Khimo!
Hi Khime, That is a wonderful outlook for the BLI out there. With thanks.
With the BLI, is it possible to change speaker settings such as listening mode, loudness etc? Idea would be to have an automation to have specific settings for example depending on time of the day.
You can easy change Speaker groups due to time of day, or Or what other inputs you want to use :)
But can you change sound settings of an individual speaker. For example, in the morning I want to listen to the news from 7-8 am on an A9 and have the listening mode set to "Speech" and loudness turned off. At other times, when listening to music I want to have it at "Optimal" and loudness on.
To answer my own question, I managed to do this with the Shortcuts app on iOS, so it should be possible via BLI as well I guess.
To turn of the Loudness for example, you make a PUT request to http://SPEAKER_IP:8080/BeoZone/Zone/Sound/Adjustment/ with the following content:
{"adjustment":{"treble":0,"bass":0,"loudness":false}}
I could not find a description of the API, but you can simply do the action in the B&O app and catch and replicate the request. For beosonic you can do the same, but the request is a bit more complicated.
For Mozart products the API is different, the URL would be http://SPEAKR_IP/api/v1/sound/settings/adjustments/loudness and the content {"value":false}
Hey Khimo.
It could be cool, if you could use the BLI to choose which product Beoremote Halo is associated with.
So e.g. at 8am it controls my Beoplay M5 and from 6pm, it controls my Beovision. Is this possible?
Hey Khimo.
Hi CTR,
We agree! It's a nice idea. At the moment this is not possible and it's not a simple change regarding the integration with Halo, so we'll keep it in the back of our mind and hopefully the opportunity to add this type of behavior arises soon 😕
Happy holidays everyone!
Hey Khimo.
Can you tell what "Favorites Lists" can be used for under the Interfaces tab ??
Could it be cool to get logos on his Halo for example. 🙂
I just can not find anything on this topic on your Github
Happy holidays to the Team
